Hey everyone. Recently picked up a 94 2 seater that has had a jdm swap. It's an auto with about 135k on the chassis. I have all the paperwork & the car seems to run well. I installed an auto meter boost gauge as it didn't have one. I also replaced the coolant temp sensor as I had a code 13. I am now getting code 55 but I'm only getting 6-7psi. From the research I've done I do believe I just running off the wastegates. I don't see any boost solenoids. It appears the wastegates are ran up to the balance pipe & connected with a t. I've tightened everything I can & done the usual maintenance of replacing all fluid and such. I've had to na's but this is my first turbo so could anyone point me in the right direction? I'm assuming I'm looking at either an ebc or a manual boost controller? Thanks
New to me 94 na/tt swap questions - Bigmatthew8615:46:02 10/29/16
